I'm finally getting around to wiring up the KFlop&Kanalog I purchased at the start of the year, to some Kinco CD422 servo drivers.
This is the first time I've ever used servos, and I'll admit I am struggling a little bit deciding all what needs done.
My first question is Speed mode or Torque mode?
I've read various arguments about each, but what would be the best to get started with?
Having had a look at the wiring diagrams for the CD422 drivers, both Speed and Torque modes show two analogue inputs. In the case of Speed mode, you have +/-10V speed command on Ain (Analogue in) 1, and a 0-10V torque limited command on Ain2. Whereas Torque mode you have +/-10V on Ain2, and 0-10V velocity limited command on Ain1.
I'm guessing I only need to connect the +-10V signal for what mode I use, and just
ignore the other connection?
My general wiring plan is the Drive logic power (24V) remains constantly powered, with the Drive main power supply coming via an Emergency stop contactor.
The Drive enables get controlled by the KFlop/Kanalog, with a drive ready signal taken back to the KFlop so the KFlop knows things are good, with the drive error signal linked into the E-stop circuit to stop things if something goes wrong.
Does all that sound plausible?
Moray
